Injector not firing HELP!!!!!!
Old Nov 22, 2004 | 11:58 PM
  #16
Dfetter84's Avatar
Re: Injector not firing HELP!!!!!!
I've already done this.....I have continuity from the fuse to the injector its either in the computer or the engine harness itself not the body harness.
Old Nov 23, 2004 | 11:10 AM
  #17
slimdawson's Avatar
Ok, so you have no power at any time at the injectors? Simple fix. Find where the power wires for those injectors terminate. Splice it into another circuit. Just pick one that doesn't overload it, replace with a slightly higher amp fuse and go. Just make sure that the circuit is hot in cranking and run position.
Did you check to see if you had power at any time(during cranking too)?
Old Nov 23, 2004 | 01:00 PM
  #18
Drakar's Avatar
you could also bypass the fuse block and run an inline fuse with both injector wires before the block and tie them into the large pink ignition wire
Old Nov 23, 2004 | 05:56 PM
  #19
Dfetter84's Avatar
Well...I'm gonna swap pcm's before i start dicing up the harness....the last time I had it scanned it gave me a DTC code ECT high voltage.....I'm not really sure how to fix that, but now i'm starting to think this problem is connected.I've also heard that wires can give me continuity if the meltef together with another wire close to it and still be screwed up in it's functions. I also heard that I'm really just no tgetting power to 2 injectors because of crossfiring or something...So how do I know which 2 to splice into
Old Nov 23, 2004 | 06:01 PM
  #20
Drakar's Avatar
best thing I ever did when it came to my harness, was I had it off the car on the floor, and I pulled off all the coregated tube wrap, and basically took it to wires and connectors (held its form well) and traced all wires in question, pulled out about 20+ wires for sensors I didnt need (OBD2 to OBD1 conservion).
but as far as what wires to splice, the 4 pinks coming off each grouping of injectors all go into a single so 4 into 1 twice. Take that one and splice in an inline fuses find the other and do the same then splice the 2 into one wire and connect to the large pink wire coming off the fuse block used for ignition.
Old Nov 29, 2004 | 03:48 PM
  #21
Dfetter84's Avatar
Well I swapped the PCM's and it's still doing it. Does anyone know anything about swapping body harness' in doing the V6 to V8
KYWes
Jun 14, 2022 06:52 AM
Anon
Jul 23, 2015 12:18 PM
RUNMYTA
Jul 15, 2015 07:50 PM
gonzo275rltw
Jul 11, 2015 04:19 AM
surreybrad
Jul 5, 2015 10:36 PM
