Disfunctional cruise control
Old Nov 28, 2004 | 08:11 PM
94ta383's Avatar
This is following my 6-speed swap. Everything else works, speedo, etc., just no cruise.
VSS is wired in correctly I assume 'cause the speedo works. Brake lights operate correctly, so that rules out the brake switch I'm guessing. I am running a T56 PCM.
1)Would I have altered anything else doing the swap?
2)What are some other problems I should look for besides the third brake light?
3)How do I know if the cruise module is faulty?
Thanks in advance for the help.
Chris
Old Nov 28, 2004 | 10:26 PM
rlax31's Avatar
Re: Disfunctional cruise control
i'd say try to move your brake pedal switch (the white thing with the button on it) I've heard that not being in the right place can cause cruise problems.
Old Nov 29, 2004 | 03:52 PM
94ta383's Avatar
Tried that one and checked the CHMSL. No dice.
Any other suggestions?
How do I know if the module is bad?
edman
Mar 13, 2015 09:39 PM
jayblev95
East South Central
Feb 15, 2015 02:26 PM
jayblev95
Jan 6, 2015 11:52 AM
