Injector ?????
Old Jun 8, 2008 | 12:24 PM
Dannysz28's Avatar
Injector ?????
I am running a 383 with AFR Lt4 heads and intake. I am putting a powerdyne supercharger on it running 9lbs of boost and was wondering what size injectors i should go with. I have 36lb svo injectors in it now and was wondering if they are to small?
Old Jun 8, 2008 | 12:46 PM
Stl94LT1's Avatar
I would run SVO 42's, at the least.
Old Jun 8, 2008 | 09:42 PM
How does your control system add the extra fuel for the blower? Does it have an FMU, or has the PCM been tuned based on a 2-bar MAP sensor? That will determine how you size your injectors.
Old Jun 9, 2008 | 10:42 PM
Dannysz28's Avatar
It has a fmu
Old Jun 9, 2008 | 10:57 PM
The FMU raises the fuel pressure based on boost. The FMU's ratio of fuel pressure psi increase:boost psi will determine the maximum fuel pressure, which determines the effective flow rate of the injectors. You need to know the HP rating of the engine at 9# boost, and the fuel pressure to size the injectors. I'm thinking even 42 #/HR (rated at 2.7bar) might not be large enough. Might be looking at something closer to 50 #/HR, depending on the ultimate HP.
Probably a good idea to post this on the Forced Induction fourm for guidance.
G-BODYT56
Jan 14, 2022 11:14 PM
magman
Apr 15, 2016 03:08 AM
autoxr166
Sep 25, 2015 04:21 PM
form94
Sep 23, 2015 07:30 AM
95blkss
Sep 22, 2015 03:18 PM
