(inches of lash)/(turn of nut)
Old Sep 29, 2003 | 01:09 PM
natZ's Avatar
For my new lifters CC gave me the lash in inches, which makes sense for them. However, what works for me is now much of a turn. How many inches is a turn of the rocker arm nut? Factory stock studs. Thanks
Old Sep 29, 2003 | 01:19 PM
grygst76's Avatar
Re: (inches of lash)/(turn of nut)
No such thing, you need a feeler gauge, they gave you a number like 28" intake 34" exhaust right? that means the size feeler gauge you put between the rocker and the valve when at circle.
Is that a solid roller? If it's hydraulic roller set it running and hot, they might have given you prelim numbers.
Old Sep 29, 2003 | 01:34 PM
dobe's Avatar
did my HR setup half turn past zero lash
Old Sep 29, 2003 | 02:34 PM
natZ's Avatar
The number they gave is a range for the lash 0.02-0.06" This is just by memory so it could be off by an order of magnitude. I know I've seen people state the (inches of lash)/(turn of rocker nut) for factory stock heads. When I put them in I went 1/4 turn past lash while hot and running. I haven't had any immediate problems, I just wanted to follow up and make sure that a 1/4 turn was within the range CC gave. Thanks
Old Sep 29, 2003 | 02:53 PM
BUBBA's Avatar
Hydro cam, 1/2 past 0. JMHO
Old Sep 29, 2003 | 03:05 PM
snorkelface's Avatar
Just a quick question as I've never fully understood this. What is 0 lash (AKA how do you know you've gotten to that point when tightening the rocker arms)
Old Sep 29, 2003 | 03:22 PM
natZ's Avatar
I'm pretty sure if you had a hydraulic cam with comp cams R lifters people have said you would want 1/8 turn past lash.
Old Sep 29, 2003 | 03:28 PM
BUBBA's Avatar
0 lash is when you just feel a slight drag when you twirl the push rod between your thumb and index finger with the valve closed.
ONE way of adjusting preload.
Coil wire off.
Bump engine til Ex just starts to open. Adjust Int.
Bump again til INT opens fully and is on way to roughly half closed. Adjust EX.
Start with either bank and work your way around.
You might want to warm engine up. Start with one bank. When complete. Warm engine up again and remove valve cover on remaining bank and complete that one. (If you remove both v covers at the same time, the second bank will have cooled down before you get to it).
You probably don't have to adjust them hot, but it would'nt hurt to have all the lifters nicely primed. JMHO.
Old Sep 29, 2003 | 03:31 PM
Coil wire off.
That's some good info to get me started. Hopefully I'll have to put it to use soon.
Old Sep 29, 2003 | 05:25 PM
OldSStroker's Avatar
7/16-20 rocker arm nut threads (aka 7/16 fine) are 1/20 or .050 inches per turn.
1 flat on the nut is 1/6 *.050 or .0083. Figure .008/flat.
If you are adjusting hydraulics, BUBBA's method for finding zero lash is good, and you are then compressing the lifter.
Old Oct 6, 2003 | 03:20 PM
natZ's Avatar
So if Comp Cams says that they should be preloaded to 0.006" while the engine is hot. That number came with the lifters and is posted on their website. That would be (0.006")/(0.05"/turn), or about 1/8 of a turn past lash. I know I've heard that the "R" lifters are supposed to be adjusted to about an 1/8 of turn past lash but I didn't think that the Pro Magnum were also. I'm going to adjust my valves to this, so somebody please let me know if I'm doing something wrong. It worries me a little that the range of adjustment is actually 0.002"-0.006", where the loose end works out to 1/25 of a turn, can that be right? It's got to be pretty tough to determine zero lash within 1/25 of a turn in order to be able to make that adjustment properly.
Old Oct 6, 2003 | 03:37 PM
JordonMusser's Avatar
West South Central Moderator / Special Guest
I think you are reading WAY too into this. that is the beauty of hyd rollers, the lash is not super critical.. aim to be around 1/8th-1/4turn and you will be fine.
Victor Lamb
Aug 26, 2017 02:52 PM
NewsBot
Apr 11, 2015 11:44 AM
FredM
Apr 10, 2015 02:56 PM
CaRParts102
Dec 6, 2014 08:45 AM
formula79
26
Aug 5, 2002 12:21 PM
