Impala LT1 w/ Hot Cam
Old Jul 24, 2004 | 07:12 PM
944v8inDFW's Avatar
Silly question. I am starting another project, because of the steal of a deal i will be using a Impala SS engine. Can I do a LT4 hot cam kit in it and or use the LT4 ED timing set in it? This will be a all bolt on motor, no porting. BTW the Impala engine is a 96 that I have already planed to convert to ODB1 unless CATS gets off thier a** and make Tuner work with odb2. Any sugestions would be helpful. Also are the ports in the Impala still a D port? Thinking ahead to headers.
Old Jul 24, 2004 | 10:33 PM
96capricemgr's Avatar
Re: Impala LT1 w/ Hot Cam
Seeing as it is the same shortblock as the f-body yes the ED timing set and HOT cam will work. The heads flow just as well as the best aluminums too so you do have a good starting point.
Old Jul 24, 2004 | 10:47 PM
944v8inDFW's Avatar
Thanks 96. Do you know if the iron heads are D port head?
djangoroar
Parts Wanted
Feb 21, 2015 11:47 PM
GigaMp3z
Feb 20, 2003 02:57 PM
Burn_Out
Aug 18, 2002 08:49 AM
Smokn '94 Z
Aug 4, 2002 06:11 PM
Smokn '94 Z
Jul 28, 2002 02:38 AM
