I'm a cam dummy!
Old Jun 25, 2004 | 01:47 PM
Briank8811's Avatar
I'm a cam dummy!
Well I have a good excuse. When i was building up my 383 with my fathers help, he decided that a LT-4 HOTCAM would be almost too radical for my motor. I have to admit that its a nice cam(I bought the whole kit). I just wish I was going to make around 400RWHP which isnt going to happen with a hotcam in a 383. What cam should I use and is the GM 847 a good choice that will net me close to 400RWHP with some LT's??? I know you all can wack me with the dumb stick
Old Jun 25, 2004 | 02:19 PM
96capricemgr's Avatar
The HOT cam in a stroker will be very mellow most will tell you down right too small. Sounds like your Dad is like mine, worked on old muscle cars and derived his knowledge from there, granted the engines have not changed all that radically but the rules have, he will not realize that till you put in a big cam and then he drives it. What heads are you planning to run?
Old Jun 25, 2004 | 03:59 PM
OldSStroker's Avatar
LOL here. I'm a Muscle Car era guy, too, but try to keep up to date with things. Cam design has progressed many orders of magnitude since Mac McKellar was designing cams at Pontiac with mechanical calculators ('60s). I have been fortunate enough to know Mr. M, as well as one of the best around today, a Mr. G. from Comp.
Better design programs as well as roller lifters which allow aggressive profiles, and better production machinery, and better valve train parts have all contributed to better power/torque/driveability.
This is THE question. The cam should be chosen after heads, intake, exhaust, intended use, gearing and driveability issues are determined. Think of the cam as the dependant variable which is the result of all the other stuff factored in.
IMO, if you don't spend some $ improving head flow, you aren't going to take much advantage of those extra cubes. Think seriously about head work before you do any more cam changing.
Don't be too hard on your ol' man.
My $.02
Old Jun 25, 2004 | 04:03 PM
Briank8811's Avatar
Well this is the best description i could come up with my heads when i had seen them last week before all the accessories were bolted on......
I dont know much about port work but when i looked at my motor before the install i could tell where they took a little over 1/4 inch of material off the intake ports to make it smooth and it gets bigger as it nears the intake(looks like a square funnel with rounded edges and i can tell when i look into the motor i can see where there has been machine work on the metal surrounding the valve(sorry for lack of technical term). Other than that i couldnt see anything else. And the guy said he performed a 5-angle valve job and the heads were plained and the block was decked(compression??). And the exhaust ports were machined lightly.
Old Jun 25, 2004 | 04:04 PM
Briank8811's Avatar
You damn people got me in HP fever before i even get to drive my damn car! LOL. Now im planning on yanking out that hotcam before it hits the road!
Old Jun 26, 2004 | 10:24 AM
Briank8811's Avatar
Any ideas?
Old Jun 27, 2004 | 09:59 AM
Originally posted by Briank8811
Any ideas?
Get the heads, and maybe the intake manifold professionally flowed, then have an engine designer spec out your cam timing and valvetrain based on that and all the other engine/driveline factors. It has worked for others. Probably will cost a little.
Or you could take a poll. That's free.
Old Jun 27, 2004 | 02:22 PM
SS MPSTR's Avatar
So is throwing darts at a dart board with the various cam names/numbers tacked up on it. I was going to use that method, but decided to call Phil at AI instead
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
