I'm burning oil
Old Dec 21, 2003 | 12:38 PM
terlox's Avatar
I'm burning oil
She loses about 1 qt. every 400 miles. What's the deal?
Old Dec 21, 2003 | 01:08 PM
predator's Avatar
leak, bad rings, valve stem seals
Old Dec 21, 2003 | 01:29 PM
Spinner's Avatar
I was thinking a ring(s) myself
Old Dec 21, 2003 | 01:35 PM
terlox's Avatar
Could I get to the rings by leaving the engine in the car and pulling the heads?
Old Dec 21, 2003 | 01:39 PM
predator's Avatar
nope gota pull it and take pistons out...do a compression test and see if it is in tolerances
Old Dec 21, 2003 | 01:41 PM
tanker's Avatar
do a copression test to see which piston has bad ring. sounds like time for a rebuit for me.
Old Dec 21, 2003 | 01:43 PM
terlox's Avatar
I'd just need to pull the spark plugs to do a compression test right?
predator's Avatar
yes sir
Old Dec 21, 2003 | 01:46 PM
terlox's Avatar
Assuming I reuse my block, how much would it cost me to do a rebuild to LT4 specs? I might as well do some improvements while it's out...
Old Dec 21, 2003 | 10:19 PM
S.J.S.'s Avatar
Depends if you have the heads...intake and stuff already. The LT4 kit costs like 1800 to 2K. I would just do a 355 and some headwork. Would be way cheaper and better than going for the LT4 conversion.
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
surreybrad
Apr 22, 2015 06:40 AM
Wilson
Aug 20, 2002 10:36 AM
PGR
Jul 19, 2002 05:55 PM
