ignition stuck
Old Aug 13, 2005 | 02:28 PM
1FASASZ's Avatar
Angry ignition stuck
my key is stuck on the on position and i cant turn it back or start the car. i had to pry the ignitoin back to turn the car off. anyone ever have this proplem? what should i do?
Old Aug 13, 2005 | 03:53 PM
Birdman7389's Avatar
Re: ignition stuck
Was your car an automatic originally?
Old Aug 13, 2005 | 08:26 PM
Re: ignition stuck
The rods and sector that operate the ignition switch could be jammed or the switch, itself, could be broken. You should be able to disconnect the rod from the ignition switch, so you can see if the key and rods will then operate freely. If so, it's time for switch replacement. A guide for that can be found on my Tech Page.
Old Aug 13, 2005 | 10:55 PM
1FASASZ's Avatar
Re: ignition stuck
ill try that. so you dont think it could be the actuall lock cylinder?
Old Aug 13, 2005 | 11:45 PM
Re: ignition stuck
You won't know until you disconnect the rod from the switch. It's the easiest way to begin isolating the trouble, IMO.
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
PopoFormula
Oct 12, 2015 04:19 PM
68camaroboltz
Oct 5, 2015 11:56 PM
tommalcolm
Sep 11, 2015 03:39 PM
