Ignition problem? Help...
A friend of mine who moved to Florida recently (he's got a 96 Z) has this weird problem and I sent him a different PCM to see if it will help, but it seems like it runs just the same with the new PCM.
Anyway, he has some hesitation/loss of power between 4800 and 5300ish RPM 3/4 throttle to WOT. At part throttle, he can go through entire RPM range without a problem. After the lag, the car pulls strong up to 6K WOT.
He also says his PCM is throwing a #5 missfire code at idle, but he's pretty sure the engine doesn't misfire.
He replaced the plugs, wires, opti, injectors and now he has a different PCM from me and still has the same problem. Don't know if this will help, but his mods are 3.73s, bbk shortys, flowmaster exhaust, 52mm TB, GMAF, K&N CAI, 160 stat, 1.6 rockers, accel 26# injectors, Crane digital ignition, and his car is a 6 speed.
I'm thinking it could be the optispark even though he recently changed it. (he said he had the same problems before the new plugs/wires/etc) Maybe the ignition control module or ignition coil?
Any other ideas?
Thanks.
Any other ideas?
Thanks.
if he did the ignition box and it only got worse that would go back to looking like a coil or module to me. If the Crane box was unhooked and the coil wasnt getting enuff or the module wasnt either than that could be the issue. Some of those modules dont like heat like mine. I moved mine to the fender and extended all the wires out
Dylan Latshaw
Mar 21, 2015 09:48 AM
Oncomingstorm22
Jan 22, 2015 07:15 PM
It could be breaking down under a load. ICM and opti are always suspects.
