ignition problem?
Old Jan 15, 2005 | 03:47 PM
stupid4901's Avatar
ignition problem?
Today I went through i rather large puddle. The water was probably about a foot deep and after I went trough everything was fine. About 30 mins later i start to get really bad static coming hrough my right speaker that increases as engine rpm increases. When I'm completely stopped there isn't much if anything but as soon as I give it gas it messes up. is this feedbalk from the ignition or something else?
Old Jan 15, 2005 | 07:09 PM
blue's Avatar
Re: ignition problem?
Do you know about the Optispark? They can be depended on to fail sooner or later, and many who are familiar with the design grit their teeth when they drive through a large puddle. Although, I'm not sure the distributor has any part in the circuit the speakers are on.
Old Jan 16, 2005 | 10:02 PM
stupid4901's Avatar
I thought it might be the opti. it's not the circuit that the speakers are on cause it only increases with engine rpm, i figured it was because of the spark giving radio disturbance or something.
Old Jan 19, 2005 | 01:12 PM
stupid4901's Avatar
ne more ideas?
Old Jan 20, 2005 | 04:44 AM
slopokrodrigez's Avatar
Look under the hood when it's dark out and see if there are any sparks. Look up from underneath the front also so you can see the wires going to the opti.
liamcg97
Nov 25, 2019 05:55 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
Mar 13, 2016 03:39 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
