Ignition Problem?
Old Jan 26, 2004 | 09:27 PM
StoneRhino's Avatar
Ignition Problem?
I bought my '94 Z28 a few months ago. It currently has 101K miles on it. The one problem I have is after it is at normal temprature it will miss when under load. say after I make 1st to 4th gear shift (cags). If I give it to much throttle it will miss Intermittently. I have replaced plugs, wires and coil. Is this a symtom of a bad Ignition control module or do I need to start looking for a new opti-spark?
Thanx
Old Jan 26, 2004 | 10:08 PM
Either the ICM or opti can act up because of heat, so it might be a little hard to track down. Chances are it is the opti, if it is the original with that many miles.
Old Jan 26, 2004 | 10:20 PM
StoneRhino's Avatar
I believe it is the original. Is their any way to tell for sure. The Helm book doesn't seem very helpful.
A couple other questions.. Since I might have to replace the opti-spark would it be possible to to convert everything over to the vented from '95's and up? If you can, would the upgrade be worth the trouble?
Old Jan 26, 2004 | 11:22 PM
Anything intermittent and especially the opti is hard to diagnose.
If you are up for a cam swap, then the vented is viable, IMO. There are many things you have to change, though. Just to swap for the sake of going to vented is costly. There are guides on venting the non-vented ones, too.
Info on swap:
http://para.noid.org/~muttvette/opti.html
liamcg97
Nov 25, 2019 05:55 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
Mar 13, 2016 03:39 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
