Ignition no power problem
Old Dec 8, 2023 | 11:49 AM
Husker973's Avatar
I have a 1996 camaro z28 i just bought.I noticed that the cooling fan is running all the time when car is on. I checked the fuse box and noticed a jumper wire from the number 3 cooling fan relay to the ignition fuse. I took the jumper wire off and noticed the car wouldn’t start, just crank. The ignition fuse gets no power without it jumped from the cooling fan. Wondering what might have caused this.
Old Dec 8, 2023 | 04:29 PM
Re: Ignition no power problem
Possibly the 12 volt supply wire to the ignition fuse is not functional, so they tapped fan #3 relay to provide 12 volts. Just a guess.
Ignition fuse should be 10 amp, supplying the ignition coil module (ICM) and the ignition coil. Also supplies the crankshaft position sensor, but that is only used for misfire detection, and will not prevent the engine from starting.
Have you scanned for codes? Is the SES light functional in "bulb check"?
Beyond that, all I can do is offer you a free download of the 1996 factory service manual, courtesy of GaryDoug:
https://www.mediafire.com/?40mfgeoe4ctti
Old Dec 8, 2023 | 04:59 PM
Husker973's Avatar
It has codes p1641, P0400,p0412 and p1642
Old Dec 8, 2023 | 07:13 PM
P1641 and P1642 set because the fan relays were “on” when they were supposed to be off.
P0400 is for the EGR system…. not related to the jumper wire. P0412 is for the secondary AIR system control. Those last two appear to be related to the previous owner disabling emissions.
Was the “SES” light on? Should be with those codes. Does the “SES” light come on during the 3-second bulb check when you turn the key to “RUN”. If not, someone may have disabled the bulb to cover up a lot of problems with the car.
Old Dec 13, 2023 | 10:44 PM
GaryDoug's Avatar
Prominent Member
Yep, someone "white-guy rigged" it up badly. You car has a wiring problem and the fix was a band-aid. We may be able to get to the bottom of this if you are willing to do a lot of work. I am available next year about mid-January ;-)
Old Jan 7, 2024 | 11:18 AM
Wonder if he figured this out. Came back to this site on 1/2/24, but didn't bother to update us.
Old Jan 7, 2024 | 10:06 PM
Husker973's Avatar
The connection was very loose where the ignition fuse goes in. Just had to tighten it.
95Clunker
Mar 9, 2011 01:12 PM
Hitower
Aug 10, 2008 08:41 PM
wiked95ta
Aug 9, 2005 09:36 AM
FastWhiteTA
Mar 5, 2004 05:39 PM
