Ignition Control Circuit
Old Jan 4, 2004 | 04:49 PM
jarek5_7's Avatar
Ive got code #41 Ignition Control (IC) Circuit open.
my car misses over 4k rpms
where`s Ignition Control Circuit? how can I check it?
also I`ll replace coil, before buying an opti :/
Old Jan 8, 2004 | 07:05 PM
slopokrodrigez's Avatar
The PCM will set a 41 when the signal from the PCM to ICM has a problem. This signal is on the white wire of the ICM and goes to pin B and at the PCM is on the black connector pin 5. The first thing to do is disconnect both connectors and check continuity from pin B of ICM to pin 5 of the PCM connector. You may need a second wire to reach it with meter. Obviously if there is no continuity, you have a wire to fix.
If ok, connect both ends and put the meter on AC Volts. While cranking the engine, look at the signal on the white wire of the PCM. It should have between 1 and 4 volts AC on it. Remember to ground the black lead.
If no AC signal, pull the connector at the PCM (black connector) and check the signal coming out of pin 5. If there is no signal coming out of pin 5 then most likely (notice I said most likely), the PCM is bad.
If the AC signal is getting to the PCM on the white wire, you must now look at the signals from the ICM to the coil. Ignition off. Meter set to DC Volts. First check for a good ground to the ICM. Put a meter lead on the + battery terminal and probe the black wire pin C on the ICM with the other lead. It should show a full battery voltage (12 or more volts).
If not you have a bad ground.
Ignition on. Meter set to DC Volts. Now check the pink/black wire on pin A of the ICM and the white/ black wire on pin D of the ICM for battery voltage (12 or more volts) remember to ground the other lead.
If the voltage is there, the problem is the coil. If it is not on those 2 pins, you have to determine if the wire from the coil to the ICM is broken, or if the connectors are bad or the coil is bad.
Also if the voltage is not on those 2 pins, check the #11 fuse (10 amp) the supplies the ignition. If blown, no voltage either.
If the AC signal is getting to the ICM and the ICM has 12 volts on pins A and D, the ground is good to the ICM, and you still have no spark the ICM is probably bad.
Old Jan 9, 2004 | 02:01 AM
jarek5_7's Avatar
thank You very much for this instructions , I`ll do this
DirtyDaveW
Dec 1, 2016 05:37 PM
timmy39120
May 8, 2015 11:41 AM
thenewkid
Apr 12, 2015 07:42 PM
PaulN64
Aug 8, 2002 05:39 AM
