ignition / coil upgrade
Old Aug 27, 2003 | 11:58 PM
dren70's Avatar
From: brunswick ohio, small burb south of cleveland
i purchased a new crane hi-6 ignition and an lx-92 coil to go with it. i went to the dealer to ask a few questions and a tech told me not to change the coil. he said the stock coil (95 Z) puts out 60,000 volts. can anyone confirm this for me? the crane is only 55,000 so i am now i dont know which to use. any information would be greatly appreciated. thanks.
carl
dren70@hotmail.com
Old Aug 28, 2003 | 09:02 AM
Lt1Tim's Avatar
I have the same ignition fireball HI-6CD. I can tell you that the stock coil will not work with the HI-6 ignition. The coil will either short out or you will damage the ignition box. Also the stock coil resistance on the primary side is from .3 to 1.3 ohms. the crane LX92 or PS92 is .2 Ohms. The secondary side of the stock coil is between 5000 to 7000 ohms. the crane Lx92 or Ps92 is 3500 ohms. The Crane coil is matched to the ignition box. I just had to replace my coil becuase the HI-6cd ignition I have my stock coil. The resistance numbers for the coil came straight from Crane yesterday. I have to order a new PS92 coil before I can use my ignition box again.
Old Aug 28, 2003 | 10:30 AM
magius231's Avatar
I have heard upgrading the coil on your car can cause the opti to fail sooner. At the same time I did mine 10,000 miles ago and haven't had an issue yet (also didn't notice any difference).
thenewkid
Apr 12, 2015 07:42 PM
thenewkid
Nov 27, 2014 09:41 AM
CARGASM
Sep 4, 2002 11:17 AM
CARGASM
Mar 28, 2002 05:41 PM
CARdiac
Nov 28, 2001 03:26 PM
