ignition coil
Old Mar 15, 2004 | 10:20 PM
BiGGinZ's Avatar
Question ignition coil
Ignition coil bolts very hard for me to get to. I cant get a grip on them need some advice.
Old Mar 15, 2004 | 10:27 PM
95BlackTA's Avatar
I think the coils sitting on a heat sink, which also has the coil module attached to it. You must take that whole thing off, then when you have that free you can remove the coil.
Old Mar 15, 2004 | 11:01 PM
Terran2k's Avatar
what bolts, the one holding it on the block? i had to remove my intake elbow and some pb blaster i think its called to help break the bolts free.
Old Mar 15, 2004 | 11:04 PM
BiGGinZ's Avatar
Its the two little bolts going through the coil holding it on there.
Old Mar 15, 2004 | 11:11 PM
Terran2k's Avatar
I am not sure if you're talking about the rivets that hold the coil in, I had to file the heads off to get them out, but try this link from shoebox's site, i used it when i replaced my coil a while back...
http://shbox.com/page/coil1.html
just go through it using the next button on the bottom of that page, til u reach the part you need.
Old Mar 15, 2004 | 11:18 PM
BiGGinZ's Avatar
Actually that looks like it is going to help out a lot. I will try it out tomorrow and tell you how it goes. Thanks.
Old Mar 16, 2004 | 12:03 PM
Laymaster's Avatar
I just did this yesterday. I drilled out the bolt/metal whatever you wanna call it holding the coil in. It was a bit of a pain in the rear, but just used a cordless drill (with some used motor oil and a lot of pressure) and then just used a screwdriver to pry it off.
Kempster
Jul 7, 2020 11:00 AM
markzzzz
Aug 17, 2015 11:08 AM
asilomar244
Jul 12, 2015 05:53 AM
94Z28LS1toLT1
May 27, 2015 10:44 PM
