ignition coil
I am not sure if you're talking about the rivets that hold the coil in, I had to file the heads off to get them out, but try this link from shoebox's site, i used it when i replaced my coil a while back...
http://shbox.com/page/coil1.html
just go through it using the next button on the bottom of that page, til u reach the part you need.
I just did this yesterday. I drilled out the bolt/metal whatever you wanna call it holding the coil in. It was a bit of a pain in the rear, but just used a cordless drill (with some used motor oil and a lot of pressure) and then just used a screwdriver to pry it off.
