ignition advice
Old Feb 20, 2009 | 12:09 PM
OPies57's Avatar
ignition advice
im starting to put the car back together and i need to buy an ignition box im most likely going to buy a digital 6 but not sure what coil to go with. i have a 93 trans am with a 383 w/ bolt ons ported heads and a custom ground cam etc..
Old Feb 20, 2009 | 12:25 PM
94SLUG's Avatar
No need to do anything.... I would use stock coil also, good wires all you need my friend save the bucks... If you must I would use the money towards LTC box, or LS1 coils...
EDIT I see your going to be on the gas, dunno now....
Old Feb 21, 2009 | 12:25 AM
rskrause's Avatar
Moderator
I agree - you will gain nothing over the stock ignition.
Rich
Old Feb 21, 2009 | 09:34 AM
OPies57's Avatar
so digital 6 with a stock coil?
Old Feb 21, 2009 | 09:57 AM
96capricemgr's Avatar
For NA I would not bother with a box unless you are looking for a rev limiter in case of missed shifts.
For nitrous the Mallory 685 is nice, rev limiter, timing retard, window switch all in one package.
These are not 80s cars that benefit from aftermarket ignitions, the stock system works really well, I saw no gain when I put an Accel 300+ on my car, I left it on only for the rev limiter. I only tried it because I got it new in box for less than half price.
Old Feb 21, 2009 | 01:12 PM
OPies57's Avatar
well i do plan on using nitrous thats the main reason why i wanted the box and for the 2 step rev limiter but other then that they really dont make that big a difference?
Old Feb 21, 2009 | 03:44 PM
94SLUG's Avatar
No difference... Our ignition stock kicks a$$.... Most FI guys dont use a box either...
Old Feb 21, 2009 | 04:18 PM
With nitrous the spark based rev limiter and window switch are VERY good ideas and reason to get an aftermarket box, but NA they don't do much.
Old Feb 21, 2009 | 06:30 PM
94SLUG's Avatar
For sure! But I'm a firm beliver that the box kills the opti yet I still have mine for the rev limiter... Could just go with a N20 window/rev limiter setup skip the high voltage to the opti..
Old Feb 24, 2009 | 06:23 PM
OPies57's Avatar
wow well that is tremendous news i would have never thought that the stock ignition and coil were that adequate
thanks for all the advice
AtlasXVIII
Aug 24, 2015 11:41 PM
canuck94z28
Aug 19, 2015 05:50 PM
4586
Aug 18, 2015 07:08 AM
Rittmeister
Aug 7, 2015 01:13 AM
GT what?
Jul 14, 2015 10:17 PM
