ignition
Old Jun 25, 2010 | 10:38 AM
Bails098's Avatar
ignition
I have a 94 firebird LT1 i am popping the ignition fuse #11 in the fuses and relays box under in the engine compartment as soon as i turn the key forward one click. I am completely lost as to where i even need to start testing wires. I did do the vats by pass, i looked at the chart on shbox.com my key read 1125 i was told by a user on here to get a 1k and 100 ohm and they should be sufficient could this be the problem? If not where do i start looking? If i disconnect the coil wires the fuse does not pop.
Old Jun 25, 2010 | 11:50 AM
There is a diagram in your Owner's Manual that shows you what is on each fuse. The two devices shown for fuse #11 in the underhood box, per your Owner's Manual are the ignition coil and the ignition coil driver (IC Module). The pellet in the key wouldn't have anything to do with fuse #11 drawing excess current. The pellet is only read by the VATS module. You have a short in the coil, ICM or the wiring that connects from the fuse to them.
Shoebox has a wiring diagram:
http://shbox.com/1/95_ign_system_schematic.jpg
If you don't have an Owner's Manual, Shoebox also has a link to the online versions:
http://shbox.com/pdf/manuals.html
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
PopoFormula
Oct 12, 2015 04:19 PM
tommalcolm
Sep 11, 2015 03:39 PM
Aaront810
Sep 11, 2015 11:24 AM
