ignition
Old Jul 19, 2004 | 11:44 PM
Zeueses 97 RamAir's Avatar
ignition
I was wondering How can you tell if ignition is starting to go out, I tried to start it today and it didnt start on first try on 2 try it did, first time it just didnt do nothing then second fired right up.
Old Jul 19, 2004 | 11:45 PM
Loadre's Avatar
Re: ignition
Could be anything, opti, starter, low battery. What do you mean by wouldn't start the first time?
Old Jul 19, 2004 | 11:53 PM
Re: ignition
WELL I engage the clutch and it just doesnt start ignition I meant, then I turn key back and it fires right up.
Old Jul 20, 2004 | 08:13 AM
Red96Lt1's Avatar
Re: ignition
I would say that your fuel pump is starting to go. When you put the key in the run position, the fuel pump runs for 2 seconds. When you turn it off and then put it back in the run position, it runs for 2 more seconds. So it's probably your pump. Do a fuel pressure test. Try turning the key off, then on (with out cranking it) and then off then on, then crank it. See if it will start right up.
Old Jul 20, 2004 | 08:25 AM
Re: ignition
My freind has a scan tool what can we see on that that will tell us fuel pressure.
Old Jul 20, 2004 | 09:25 AM
Re: ignition
you there red96 ta
Old Jul 20, 2004 | 09:42 AM
HBHRacing's Avatar
Re: ignition
a scan tool will not read fuel pressure. but i agree thats a good place to start. when was the filter changed last?
Old Jul 20, 2004 | 10:41 AM
Re: ignition
last week
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
PopoFormula
Oct 12, 2015 04:19 PM
tommalcolm
Sep 11, 2015 03:39 PM
Aaront810
Sep 11, 2015 11:24 AM
