ignition
ignition
I was wondering How can you tell if ignition is starting to go out, I tried to start it today and it didnt start on first try on 2 try it did, first time it just didnt do nothing then second fired right up.
Re: ignition
I would say that your fuel pump is starting to go. When you put the key in the run position, the fuel pump runs for 2 seconds. When you turn it off and then put it back in the run position, it runs for 2 more seconds. So it's probably your pump. Do a fuel pressure test. Try turning the key off, then on (with out cranking it) and then off then on, then crank it. See if it will start right up.
tommalcolm
Sep 11, 2015 03:39 PM
