If you have a 280xfi cam, what springs do you use?
Old Feb 21, 2011 | 10:55 AM
pelensky's Avatar
I currently have 986-16 comp cam springs and the valves float at about 5400 RPM (I run the engine to about 6200 maybe 6300 max). This started only after a few thousands miles and a few years old.
I want to change them without changing the valves or rods but I need more springs. I currently have stock ported heads.
What springs are you running and what RPM do you run? How many miles and are you sure your valves don't float?
Old Feb 21, 2011 | 08:17 PM
Bersaglieri's Avatar
Re: If you have a 280xfi cam, what springs do you use?
I think Comp lists the 918's for use with that cam, but I'm no a Comp beehive guy so I'd probably run some Patriot Golds. Simple, proven, and comes with everything you need in a package. Lot's of guys turning 7000rpm easy with those springs. Also have Ti retainers.
Lloyd Elliott is where I got my last set, give him a call and see what he can set you up with... http://elliottsportworks.com/
-Dustin-
Old Feb 22, 2011 | 05:45 AM
pelensky's Avatar
-Dustin-
When I called Comp,they recomended the 987-16, but some are having float with these springs on this cam. Some have also had float with the beehives. What patriot gold do you think would work?
Old Feb 22, 2011 | 01:27 PM
Mystery Bird's Avatar
I'm using the 918's on mine, shifting @ 64-6500.
Old Feb 22, 2011 | 05:24 PM
pelensky's Avatar
What lifters do you have? What install height are you using? How many miles on the 918s? Has it been on a dyno to prove no valve float?
Thanks for your input
Old Feb 22, 2011 | 08:23 PM
Stock original lifters, 1.78, about 8k, no dyno car pulls hard right till 6400.
Old Feb 22, 2011 | 10:36 PM
Every time you call Comp it's a different person with different opinions. And I'm by no means advocating the use of beehives. Either the Patriot Golds or Gold Extremes should be fine with that cam and 1.6 rockers. Most of my LSX buddies run them [Patriots] with the most aggressive HR cam lobes to date and have very few, if any problems.
-Dustin-
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
Speeds8erM-1
Aug 20, 2002 09:12 PM
Speeds8erM-1
Aug 15, 2002 10:07 PM
Speeds8erM-1
Aug 13, 2002 10:24 PM
