if my timing gear was off by a tooth
Old Mar 10, 2004 | 10:06 AM
Seal's Avatar
car would run like crap, wouldnt it?
i heard it'll run, but just not at it's full potential which makes so sense to me, cuz 1 tooth off is alot with the lopes...
cuz my cc306 is running strong, but i cant beat my roommate's bolt on ls1... i'm going to change the plugs today cuz i'm positive that I fouled them with the stock tune (running too rich)...
so just making sure a tooth of can mean running like CRAP right (weird *** idle, wont pull @ WOT)
thx
Old Mar 10, 2004 | 10:26 AM
GetaZforgetGT's Avatar
A buddy of mine had his stock cam of by a tooth...I can't remember the circumstance that he had the car torn appart and ended up getting things misaligned but anyway.
His car had a weird backfire (very mild pop) every once in a while and just had no power but otherwise appeared to run normally.
Old Mar 10, 2004 | 11:53 AM
Cmr0z28's Avatar
Re: if my timing gear was off by a tooth
What kinda retarded a$$hole did you hear that from?
Old Mar 10, 2004 | 12:07 PM
Grease's Avatar
It will run. But you will have extremely low vacuum, around 4 inches. With a CC306 you should have atleast 11"
ChrisFrez
Dec 15, 2014 03:09 PM
Noenav
Dec 6, 2014 07:35 PM
1LEThumper
Jul 14, 2003 12:45 PM
