If Knock sensor has been disabled, do I need LT4 module?
Old Sep 30, 2004 | 09:40 AM
chrism400's Avatar
Can I sell my LT4 knock module if my knock sensor has been disabled?
Old Sep 30, 2004 | 10:01 AM
Josh-'04 GTO's Avatar
Re: If Knock sensor has been disabled, do I need LT4 module?
I'm not sure if the PCM needs a module in place if the KS is disabled. My question is why on earth you would disable the KS??? That is insane...
Old Sep 30, 2004 | 10:05 AM
NoFear95's Avatar
False knock. Plenty of guys do it. Got tired of seeing knock on mine running 100 octane so I disabled it. Plenty of guys do it when you can track it down to false knock.
Old Sep 30, 2004 | 10:07 AM
dreamer1q's Avatar
Yep, false knock. Mine was discovered on the dyno, and removed on same said dyno. You guys act like it is a catch all, and everyone uses them. Remember, they are not on a Mustang, and they seem to run just fine
Old Sep 30, 2004 | 10:10 AM
chrism400's Avatar
I was just going to replace the LT4 module with the original LT1 one if it doesn't need the LT4 one anymore. I was getting false knock ever since I installed the Hydra Rev for some reason. Madz reprogrammed my computer and disabled the knock.
Old Sep 30, 2004 | 10:11 AM
Brettinator's Avatar
Not sure about physically removing it, my understanding is they can tune the PCMs Knock Module to pull ZERO timing out. I would think physically removing it would throw a code, not sure though.
Old Sep 30, 2004 | 10:24 AM
WS Sick's Avatar
If it is physically removed it will throw a code and set you in limp home mode.
I have mine in place with an LT4 kM, and a seperate defeat circuit, that way when tuning I can turn it on to see the knock.
Old Sep 30, 2004 | 10:26 AM
izzyz28's Avatar
Knock sensors are there for the cheap bastards that put 87 in the tank. Unless your engine is majorly ****** or your tune is way off there is no need for one. As stated previously, Mustangs don't use them, and if they did I can guarantee you their owners would be bypassing them too if they were getting false knock like many of us LT-1 guys and gals are. I'll gladly trade a tiny, infinitessimal piece of mind for the ten degrees of timing that thing was stealing from me.
Old Sep 30, 2004 | 10:48 AM
slimdawson's Avatar
To answer your question, no you don't need an LT4 km. Put the stock one back in and ride.
Old Oct 1, 2004 | 07:50 PM
Uh...if you're car was making serious power, you would know that one pass with a batch of bad gas and no knock sensor would give you a lesson in the fine art of engine rebuilding... Just my 2 cents.
Old Oct 1, 2004 | 11:01 PM
slimdawson's Avatar
[QUOTE=izzyz28] As stated previously, Mustangs don't use them...
That is because Camaros are elite
Old Oct 1, 2004 | 11:24 PM
Z95m6's Avatar
Mustangs probably don't have KS because most of them only have like 9 to 1 compression ratios vs our 10.5's to 1. The best gas i can get around here is 91 octane and if i floor it in 6th i get pinging. i would keep it.
mightymouse383
Jul 20, 2016 07:34 AM
4586
Mar 18, 2015 06:31 PM
IgorT.455/406
Feb 1, 2005 06:18 AM
Nostang 96z
Sep 10, 2002 08:54 PM
dreamer1q
Aug 20, 2002 11:19 AM
