if the chip in my key is bad what will happen?
Old Apr 3, 2009 | 06:37 PM
ghost stripes's Avatar
will the car not turn over will it just not crank or what please help
Old Apr 3, 2009 | 07:03 PM
mrmint69's Avatar
I assume it will not do anything. When mine went bad it did that.
Old Apr 3, 2009 | 07:24 PM
ACE1252's Avatar
It will not do anything and the security lamp on the dash will come on and or flash.
Old Apr 4, 2009 | 06:38 AM
The "chip" is simply a resistor. You can check it as shown by Shoebox:
http://shbox.com/1/4th_gen_tech2.html#pass_key
Old Apr 4, 2009 | 12:26 PM
94arcticwhiteM6's Avatar
its usually the cylinder that goes bad not the key. it will run you about a 100 in parts from the dealer.
the wires that carry the signal from the "chip" are attached to the cylinder and will fray over time. when the signal no loner reaches the vats module it can just crank or do nothing. also the security light will come on.
liamcg97
Nov 25, 2019 05:55 PM
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
Fatdog2
Mar 31, 2015 06:50 AM
Jonnybegood
Parts Wanted
Feb 10, 2015 07:50 AM
Oncomingstorm22
Jan 22, 2015 07:15 PM
