if the bearings arent bad do i have to turn the crank??
Old Apr 18, 2010 | 01:42 PM
z28beast's Avatar
ok so last night i was looking at my rod/main bearings and there not really that bad....so when i replace them do i have to have the crank truned/polished
Old Apr 18, 2010 | 02:05 PM
bowtiedad_z28's Avatar
You can probably get away with having it polished if the journals all look good. Have a shop look at your crank and they can tell you for sure.
Old Apr 18, 2010 | 02:20 PM
z28beast's Avatar
ok cool i apprecite you input...btw how do i remove the balancer hub off the crank??/ im puzzled
Old Apr 18, 2010 | 02:31 PM
Have a shop mic your crank and resize if necessary. That way you will get the correct bearings.
http://www.lt1engine.com/tech/remove...lt1-crank-hub/
Old Apr 18, 2010 | 02:36 PM
z28beast's Avatar
shoebox your the man!!!! lol i deleted the other post...i did search but couldn't find anything helpful to me...
Old Apr 18, 2010 | 03:36 PM
z28beast's Avatar
ok so i tried removing the hub and it got to a point were i was just turning the hub on the crank and it wasn't coming off...so i got a longer bolt and put it in the hole and i got it to come off....why was the hub turning on the crank? i looked and i see a key way hole on the crank but i didn't find a key way? did i ruin something? now im nervous
Old Apr 18, 2010 | 04:54 PM
LT1 hubs are not keyed to the crank. You will see a keyway on the crank, but no key slot on the hub.
HectorM52
Jul 30, 2017 11:46 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
1996LT1Z28
Dec 1, 2014 01:01 AM
formula79
26
Aug 5, 2002 12:21 PM
