idling at 3000rpm
I put a new cam in my lt1 engine and when i start it up it idles at 3000rpm.
comp cam LT1 268XFI HR13.
Anyone have any ideas on things to check? Do I need a PCM reprogram?
Re: idling at 3000rpm
The engine needs a lot of air to idle at 3,000RPM. The only source of idle air (assuming the TB blades are fully closed) is supposed to be through the IAC passages in the throttle body. Its getting the air from somewhere else.... you need to find out how the air is getting in there.
autoxr166
Sep 25, 2015 04:21 PM
