idle way high after tb bypass
Old Mar 26, 2005 | 06:52 PM
pHEnomIC's Avatar
I did the tb bypass on my 97z and i put it back together and i turn the car on... It was idleing at 1.5k and when i put it into drive it would lunge. I did break the housing on my throttle position sensor and i think this may have something to do with it. The actual mechanisms werent hurt but the adapter was snapped off. I superglued it back together and let it dry. Does this sound like a tps problem and if so how do i fix it?
Also, i may not be putting it on right. It doesnt go on flush, i have to put it on and then rotate it to get to the right spot to line up with the holes.
Old Mar 26, 2005 | 07:17 PM
Bersaglieri's Avatar
Re: idle way high after tb bypass
Sounds like you just bought a new TPS sensor. I dont think you should drive it like it is right now.
-Dustin-
Old Mar 27, 2005 | 05:11 PM
pHEnomIC's Avatar
Just bought a new tps sensor and replaced it... CAr still acts the same
Old Mar 27, 2005 | 05:13 PM
camzaro28's Avatar
does the car buck or shut off, once u get it to turn on?
of so look at ur map sensor wire and see if u pinched it! i did when i did the TB bypass
Old Mar 27, 2005 | 05:37 PM
pHEnomIC's Avatar
I looked at the wires and one of them was torn so i resoldered it... My luck.. had like 1 mm of copper left and had to strip and solder it but it works now thanks.
Old Mar 27, 2005 | 05:42 PM
camzaro28's Avatar
was it the map wires? or what other wire was it?
no prob
Old Mar 27, 2005 | 07:32 PM
pHEnomIC's Avatar
no prob
It was the blue wire off of the tps sensor.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
lt1matt
Mar 21, 2015 07:35 PM
1996LT1Z28
Mar 8, 2015 08:16 PM
ChrisFrez
Mar 1, 2015 01:33 PM
