Idle stays higher between shifts
Old Apr 6, 2010 | 02:18 PM
ReaperWS6's Avatar
For some reason, the car likes to jump idle for a bit when idling, then comes back down to normal operating rpm. But I've noticed it when shifting too. The rpm's will stay up higher between shifts. What does this mean? IAC dirty? What would be the best way to clean it? I was just going to take off the CAI and spray TB cleaner into the bores with the engine running.
Old Apr 6, 2010 | 04:30 PM
Guest47904's Avatar
Guest
If the IAC was the problem, which is likely, it's not a dirt issue. It's more likely sticking. If the seat at the pintle had debris in it, it would never seat. But yours does. Just replace it.
Magenta_Hearts
Mar 29, 2017 08:54 PM
mattstrike
Mar 11, 2015 07:33 PM
Dark Zeiro
Mar 11, 2015 07:15 AM
1996LT1Z28
Mar 8, 2015 08:16 PM
jb4xx
Feb 2, 2015 10:00 PM
