Idle RPM Drop
Old Feb 7, 2007 | 07:10 PM
Texas_96_Z's Avatar
Idle RPM Drop
I was going to take my Z out for an evening spin but didnt want to have to tow the SOB. I cranked it up and let it warm up a bit then I noticed the RPMs would drop from about 750 to 650 every 2-3 seconds. Also the head lights would dim slightly every second or third RPM drop. The coil is new and the alternator is about 40k miles old. So what do yall think?
*Edit*
Just tried to reset the IAC, no good. SES light also came on. Could this be from fouled plugs? I had 2 plugs back out causing a misfire. Also, it's hard to start, my FPR might be on its way out. I won't be able to scan it for awhile.
Old Feb 8, 2007 | 09:20 AM
Texas_96_Z's Avatar
Anyone? Bueller....Bueller....
Old Feb 8, 2007 | 02:15 PM
mrmint69's Avatar
I would check the fuel pressure to start. Are there any codes? Mine always throws one if the idle gets that bad.
Old Feb 8, 2007 | 04:20 PM
Texas_96_Z's Avatar
SES light did come on. Gonna try and scan it soon. Thax for reply.
Old Feb 11, 2007 | 08:12 PM
Texas_96_Z's Avatar
ok, scan says p0300 which is a misfire. Since the plug had backed out a week before and caused the motor to sputter and pop, could the plug wire be fried? It idles nice except for the RPM drops. Change plugs?
Old Feb 11, 2007 | 09:07 PM
red94m6's Avatar
i have sort of an rpm drop, but its not happening so consistently, it happens randomly could be every 30 seconds every minute, two minutes whatever.
i took a video of what its doing today
http://s5.photobucket.com/albums/y17...MOV00358-1.flv
is this the same as your problem?
Old Feb 11, 2007 | 09:53 PM
Texas_96_Z's Avatar
Yes, but yours drops around 500 rpm and mine about 100 rpm, just a little hickup compared to yours. Do your headlights flicker like mine do sometimes when it drops?
Old Feb 11, 2007 | 10:25 PM
red94m6's Avatar
not really sure, never bothered to look, i will tomorrow
but if it helps it does seem like the battery voltage changes when it does that
and its hard to see in the video but it does drop to 100-200
sometimes the engine doesnt catch itself thougha nd it stalls, this damn hickup makes the car pretty much undrivable though, it happens more frequently shifting gears
Old Feb 12, 2007 | 11:45 AM
Texas_96_Z's Avatar
Anyone else have any ideas?
lt1matt
Mar 21, 2015 07:35 PM
1996LT1Z28
Mar 8, 2015 08:16 PM
camy 1993
Feb 3, 2015 06:26 PM
Alex Barnes
Jan 24, 2015 10:21 PM
97SSdude
Dec 31, 2014 07:43 PM
