idle problems after roller rockers?
i installed crane 1.6 roller rockers and after the install my car idles at 1000-1200 sometimes and then when it comes down to 800rpms it will surge up and down.the engine is a 93 speed density.performance is fine and they are not noisy either.thanks in advance for any help.
Originally posted by 93redz
so you say if the map sensor numbers are bouncing around you think the valves need reset?
and please dont do what i did. Mine were to tight the first time and my first cam..... ended up shaving my cam and replacing a bunch of stuff that could of been avoided. Now the car is in the shop getting a bent valve replaced and a nice valve job, new lifters, and new 1.5 rr's non-self aligning. shouldnt have the problem again after this either
good luck
-Mike
good luck
-Mike
the map sensor is only reading 8hgs ov vacume at idle when warmed up.
Barometer - MAP = vacuum
A stock cam will pull 20"Hg. Barometer is typically 30"Hg.
30 - 20 = 10"Hg = typical MAP reading in a stock cam.
8"Hg at idle seems a little on the low side for MAP (22"Hg vacuum), although mine would bump into the high 8.X's at times when the cam was stock.
