idle problems after roller rockers?
Old Jun 18, 2003 | 06:32 PM
93redz's Avatar
i installed crane 1.6 roller rockers and after the install my car idles at 1000-1200 sometimes and then when it comes down to 800rpms it will surge up and down.the engine is a 93 speed density.performance is fine and they are not noisy either.thanks in advance for any help.
Old Jun 18, 2003 | 06:47 PM
WS6T3RROR's Avatar
hate to say it but you're gonna have to re-run the valves. sounds to me like they're too tight chief. if thats the case the valve isnt being allowed to close properly.
Old Jun 18, 2003 | 06:50 PM
indy500ss's Avatar
Would that make it surge like that? What way do you recommend installing them?
Old Jun 18, 2003 | 07:26 PM
blownbird01's Avatar
All the valves were set at 1/2 turn past zero lash. Thats not too tight. I never had this problem before and have set many valves. The directions call for 1/2 - full turn past zero lash.
Old Jun 18, 2003 | 08:26 PM
93redz's Avatar
anyone else have any ideas?
Old Jun 18, 2003 | 08:47 PM
kjlvilla's Avatar
Put a vacuum gauge on your intake, if the needle is bouncing, recheck the valve lash. If you have access to a scanner, check the MAP for the same thing. Good luck.
Old Jun 18, 2003 | 08:51 PM
93redz's Avatar
so you say if the map sensor numbers are bouncing around you think the valves need reset?
Old Jun 18, 2003 | 08:54 PM
Teal94Z's Avatar
Check your vacuum, and double check the rockers...
Old Jun 18, 2003 | 09:46 PM
MAP, vacuum, same thing. If it is erratic, then you probably have some tight valves.
Old Jun 19, 2003 | 07:37 AM
93redz's Avatar
i will check my vacume reading.....thanks
Old Jun 19, 2003 | 08:59 AM
REPO's Avatar
Valve lash too tight.
I've been through it.
If they are ProMagnums, I only went 1/4 turn past. 1/2 turn was too much on my heads.
Old Jun 19, 2003 | 10:06 AM
93redz's Avatar
the map sensor is only reading 8hgs ov vacume at idle when warmed up.
Old Jun 19, 2003 | 10:11 AM
ONELOUDKAR's Avatar
and please dont do what i did. Mine were to tight the first time and my first cam..... ended up shaving my cam and replacing a bunch of stuff that could of been avoided. Now the car is in the shop getting a bent valve replaced and a nice valve job, new lifters, and new 1.5 rr's non-self aligning. shouldnt have the problem again after this either
good luck
-Mike
Old Jun 19, 2003 | 01:56 PM
93redz's Avatar
ttt
Old Jun 19, 2003 | 02:03 PM
MAP isn't the same as vacuum, it the "opposite" of vaccum.
Barometer - MAP = vacuum
A stock cam will pull 20"Hg. Barometer is typically 30"Hg.
30 - 20 = 10"Hg = typical MAP reading in a stock cam.
8"Hg at idle seems a little on the low side for MAP (22"Hg vacuum), although mine would bump into the high 8.X's at times when the cam was stock.
