Idle problems
Old Apr 18, 2005 | 05:35 AM
PoorMan's Avatar
Idle problems
Hey peoples. I posted on this problem sometime ago and never found an answer. I can't seem to find that thread now. 6+ months ago. I would like to find a fix because it's annoying as heck. Thanks
Cold or warm doesn't matter. In park, I idle about 1000rpm. In drive, about 900. When I change from Park to Drive the idle drops below 700rpm for a sec and almost stalls the car. It then corrects itself and goes to 900rpm. The opposite occurs going back into Park. The idle shoots up to about 1300rpm for a sec and corrects itself to 1000rpm. My pcm idle points are 1000prm and 900prm for Park and Drive respectively.
I have had this problem since I installed my heads, cam, and headers. I assume it's an IAC problem. My IAC is working I believe, it just seems slow to correct I guess. No sure though. I did clean the TB when it was off during the install. I installed all new gaskets, cleaned everything well, etc. Any suggestions would be great.
JD
Old Apr 18, 2005 | 09:07 PM
slopokrodrigez's Avatar
Re: Idle problems
What's your vacuum level and what are the IAC counts in idle and drive.
lt1matt
Mar 21, 2015 07:35 PM
edman
Mar 13, 2015 09:39 PM
Magenta_Hearts
Mar 5, 2015 07:01 AM
edman
Jan 25, 2015 02:41 PM
slothgrant
Aug 22, 2002 03:01 PM
