Idle problem SOLVED!!!!
Old Aug 17, 2007 | 07:52 PM
95zsean's Avatar
Just a bit of backgroung,I had a problem with it taking a long time to idle down at stop lights and after starting and idleing.
I took the TB off and cleaned the IAC and passages with TB cleaner,put it all back together and reset the IAC as per SHOBOX and everything is GREAT. Hope this helps someone
Old Aug 17, 2007 | 08:13 PM
chief455's Avatar
nice! Research andreading CAN solve problems
Old Aug 17, 2007 | 08:59 PM
n2ceptor's Avatar
Glad to see things worked out..... And a key thing here is "Thottle Body Cleaner"....... Carb cleaners, brake cleaners, etc.. are harsh to the TB.....
Good call.....
Old Aug 17, 2007 | 10:09 PM
bombebomb's Avatar
Nice job on the fix, cheap and not a major or expensive thing.
Old Aug 18, 2007 | 10:04 AM
95zsean's Avatar
It takes time to read,and you have to go throught all the not so good Info. but it's there and with some Mech. back ground you can do it.
AlaskaZ28
Apr 17, 2015 08:54 AM
Magenta_Hearts
Mar 5, 2015 07:01 AM
edman
Jan 25, 2015 02:41 PM
David Dorris
Jan 17, 2015 08:10 PM
slothgrant
Aug 22, 2002 03:01 PM
