Idle problem and lean on cold start only
Old Jun 24, 2007 | 09:25 PM
n2oCamaro's Avatar
What would cause a rough idle and a lean condition (15.5-16.2 afr) at cold start only. Once it goes to closed loop everything is fine and if I restart it later, everything is fine in open loop. I have logged the cold starts with Datamaster and everything looks fine except the RPM (obviously) and timing drops to around 20-24 (no knock retard).
Old Jun 25, 2007 | 12:38 PM
Check the coolant temp sensor reading at cold start. If its reading higher than actual temperature, the extra fuel added as part of the cold start enrichment will not be as great.
Old Jun 25, 2007 | 04:14 PM
n2oCamaro's Avatar
I checked it out and the temp starts at 76 and gradually climbs from there.
Gtpguy
Jan 26, 2015 04:50 PM
Britbilly
Jan 7, 2015 08:49 PM
jayblev95
Dec 1, 2014 06:55 AM
Dave19yz28
Jan 26, 2003 01:45 PM
slothgrant
Aug 22, 2002 03:01 PM
