Idle to low?
Old Dec 8, 2005 | 04:44 PM
94Formula driver's Avatar
Idle to low?
I have a 94 Formula A4. It idels between 500 and 600 rpms....is this normal or is it to low?
Old Dec 8, 2005 | 04:46 PM
OBE1 95Z28's Avatar
Re: Idle to low?
I believe the typical idle for an A4 is 650 rpm. Check for vacuum leaks as these could cause your idle to be off.
Old Dec 8, 2005 | 04:54 PM
sssalah's Avatar
Re: Idle to low?
650 rpm in neutral, 550 rpm in gear are the original settings for idle rpm of an A4 car.
Old Dec 8, 2005 | 05:20 PM
pHEnomIC's Avatar
Re: Idle to low?
That sound about normal, the stock tachometer is known to be inaccurate by up to 200 rpms. I wouldn't worry about it unless it ran bad or it was randomly stalling out.
Old Dec 8, 2005 | 05:32 PM
matLT1's Avatar
Re: Idle to low?
I agree, my a4 idles at about 550 rpm in gear and 650 in park, once warmed up.
Old Dec 8, 2005 | 06:37 PM
MyShibbyZ28's Avatar
Re: Idle to low?
Second the motion that it is normal.
andrewcapps82
May 19, 2015 10:11 PM
Noenav
Apr 30, 2015 01:06 PM
edman
Mar 13, 2015 09:39 PM
camy 1993
Feb 3, 2015 06:26 PM
Hot Rod Hawk
Aug 15, 2002 10:47 PM
