Identifying which 02 sensor connector is which...
Old Jun 2, 2013 | 10:58 PM
tylerwerrin's Avatar
hi guys,
how can I figure out which 02 harness is which? I had my harness tagged but over time, the tags came off and now i'm not sure which is which. I think i have them hooked up right, but I'm not sure. I scanned the car and I was getting funny 02 readings (lazy fluctuations, sticking at static voltages) and little pops in the exhaust once I got into closed loop. I had issues with a busted 02 sensor before, and i had similar symptoms -- the car would bog down, stumble, etc.
Is there a way to figure it out from probing the wires under the car? does anything happen if the 02 sensors are crossed that would be similar to what I'm describing above?
thanks!
Old Jun 2, 2013 | 11:23 PM
slick1hunting's Avatar
im not certain but would assume if you unhooked one of the connecters you should be able to see which bank is fluctating
Posted from Camaroz28.com App for Android
Old Jun 3, 2013 | 12:09 AM
Re: Identifying which 02 sensor connector is which...
the thing is both are fluctuating so slowly that i can't tell which is which! its very frustrating. the 02 sensors are relatively new too...
Old Jun 3, 2013 | 01:51 AM
My thought is if one is unhooked it shouldnt send a signal given it will read the one that is still hooked up it will tell you bank one or bank two. (I am on phone so also dont know what year your car is so I am assuming its the front o2 s that you think may be swapped). May also want to check the fuse for the heater on them. If you are scanning live data you can key on(engine off) and watch the volts move as they heat. I really am not sure if my theory will work but its what I would try until someone who truly knows gives a reccomendation
Old Jun 3, 2013 | 05:18 AM
Look at Shoebox's harness photo to see what other wires the left and right O2's are grouped with:
1995 Z28 A4 Engine Harness
Passenger side O2 is bundled with the starter, knock sensor and block ground, driver side O2 is bundled with the oil pressure sensor and the foil wrapped harness that goes forward to the MAF, coil, ICM, etc.
If you accidentally switch the O2 sensors harness connections, the PCM will lose control of the A/F ratio on both banks of the engine.
Old Jun 3, 2013 | 09:43 PM
97WS6SCharged's Avatar
Unplug the driver side O2 sensor and see which side sets a code. If the passenger side displays a dead O2 then you have the harness backwards.
Old Jun 10, 2013 | 11:06 PM
will.b.brown's Avatar
Ditto on what 97WS6SCharged said.
Latronaxe
Jun 10, 2015 02:08 PM
Richardan15
May 30, 2015 08:36 AM
94Z28LS1toLT1
May 27, 2015 10:44 PM
Fastbird93
May 22, 2015 08:28 PM
