Identify these pieces?
Old Jan 11, 2006 | 06:39 AM
  #16
Jeff95TA's Avatar
Re: Identify these pieces?
Yes it started making a racket, which sounded like a rod bearing.
Lifter spider is okay as are the lifters. As far as the size of the pieces in the first picture, they are sitting on a blue shop towel which is about 12" x 12".
I don't see what it could be other than a bearing since everything else seems to be surprisingly okay (I'm sure the finish isn't of course). Just not what I thought it would look like.
And there's a new short block in the future. Question is, do I trust the lifters and rocker arms. I'm going to clean them and see if the bearings still operate smoothly, but will I ever trust them again? Should I replace the valve seals too?
If I didn't have money in the heads already I might just consider an LS1 swap.
Old Jan 11, 2006 | 07:13 AM
  #17
Dave89IROC's Avatar
yup, I'd say you spun a bearing.............
Old Jan 11, 2006 | 07:47 AM
  #18
thesoundandthefury's Avatar
Were you the first person to own this engine? Did it have any machine work done to it previously before you built the motor? I was gonna guess a cylinder liner. If it slipped, (or was dragged out by a piston), the crank and rods would've beat it to the mess of smithereens like what you have before you.
Old Jan 11, 2006 | 08:31 AM
  #19
Jeff95TA's Avatar
It's been mine since day one.
I just need to get the bearings out and I'll know, but it's so much fun guessing.
It may be a little challenging though since I can't spin the crank at the moment.
Old Jan 11, 2006 | 09:45 AM
  #20
Crazy95Z's Avatar
It's definatly bearings. I've seen that before on my own Z. It sucks. Good luck with the rebuild.
Old Jan 11, 2006 | 10:49 AM
  #21
skunktones's Avatar
could be crank scraper pieces? maybe not sure pics not real up-close
Ericksd
Jan 20, 2016 06:07 PM
Fatdog2
Sep 16, 2015 11:04 PM
ZXXVIII
Sep 1, 2015 10:13 PM
detroitmuscle
Jul 31, 2015 04:21 AM
cjamen
Jul 27, 2015 12:48 PM
