Ideal compression ratio?
Old Mar 6, 2007 | 04:53 PM
69gto96z's Avatar
I am in the process of getting my motor parts list together. I will be spraying a 150 shot with Mahle Pro Pack forged pistons/scat forged i beam 6.000" rods. I will be running a Bret Bauer custom cam. I have heard nitrous motors like high compression, is this true? I will be on stock heads, and was thinking about a 11:1. Does this seem ideal?
Old Mar 6, 2007 | 04:56 PM
Maximize your N/A dynamic compression ratio (DCR) for the fuel you plan to run on the street, then put the nitrous on top of whatever the results of that calculation are. There is no "ideal" answer. You could go a lot higher than 11.0:1 SCR, and put a big shot on top of it, but you're not doing it on pump gas. If you already planned to drive around with $9/GAL C16, push the DCR up.
Old Mar 6, 2007 | 05:02 PM
69gto96z's Avatar
I plan to run on 93 octane.
Old Mar 6, 2007 | 07:11 PM
The Engineer's Avatar
The C16 is a “leaded” VP 110 octane race fuel I believe, what will the C16 w/ lead do to the front o2 sensors on an LT engine?
WD
Old Mar 6, 2007 | 07:29 PM
95Blackhawk's Avatar
Talk in terms of DCR not SCR. What is the DCR you plan on running?
Old Mar 6, 2007 | 07:51 PM
69gto96z's Avatar
What is the difference between DCR and SCR? I am new to building motors.
Old Mar 6, 2007 | 08:46 PM
http://www.empirenet.com/pkelley2/DynamicCR.html
Here is a little bit of info. What I did was start to read posts and do research plus talking to my engine rebuilder. My rebuilder had no problem suggesting a high DCR to me. I was skeptical at first but I have not had problems but then again I spent the money on a dyno and know how to do my own tuning. We will see in July but I can always just pull timing for the summer...I don't really care about the 10 ft-lb of torque I would lose for that time of year anyway.
Ben
Old Mar 6, 2007 | 09:03 PM
69gto96z's Avatar
Thanks for the link. I am building my own motor, just getting some basic machining done and have been talking to Bret Bauer about what pistons he recommends for what I want. Hopefully I can get more informed before I start spending more money in the next couple of weeks.
Nayr
Mar 3, 2023 08:34 PM
13qtr
Oct 28, 2016 08:11 PM
surreybrad
Sep 29, 2015 09:00 PM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
