ICM question
Old Dec 13, 2007 | 06:23 PM
volZfrk's Avatar
ICM question
A brief history, car (94z) was running fine when cold, and as it came up to operating temp., it would cut out and shutdown. Scanned it and everything pointed to the icm. Replaced it with a new GM unit and now the car barely idles when started. It's not throwing a SES light, and I'll probably have a friend scan it again this weekend.
Everythings connected and tight. Am I overlooking something simple? Coil is new also.
Any ideas?
Old Dec 13, 2007 | 09:07 PM
ricehammer's Avatar
Did you get all the grounds connected back to one of the two bolts that holds the ICM and coil to the head? How much cranking (if any) did you do while trying to diagnose the problem? If you cranked it a bunch, without it running, there's a good chance you fouled out some plugs. I did this when my ICM died.
Old Dec 14, 2007 | 03:01 PM
volZfrk's Avatar
The car starts easy, it just won't idle right. I don't think the plugs are fouled. I'm pretty sure I got everything hooked back up, but I'll double check this weekend. I dunno
maybe2fast
Mar 16, 2015 09:45 AM
grgguy
17
Feb 23, 2015 07:57 PM
blac94Z
Exhaust System
Feb 17, 2015 04:14 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
USAirman93
Nov 24, 2014 03:37 PM
