Icm
Old Jun 17, 2007 | 03:14 AM
nader454's Avatar
Icm
I know there have been a lot of driveabilty posts lately, hopefully someone has run into this. Went to the dragstrip last night, 100 miles, the car missed very faintly a couple times.(93 Z28 6m) Made my pass, then when I got my timeslip, the car would barely run. Chugging, bucking, popping and carrying on. Now it wasn't a faint miss. I let it sit, then decided to head home. Fired up fine, crisp throttle reponse. I let it idle while airing up the tires, then the exhaust note changed, same deal. It was a trick to get it moving, it wouldn't rev up, had to lunge forward. Ran crappy till I hit 4 lane. The temp went from 95 to 80 outside. The rest of the trip it didn't miss a beat. All day today it wouldn't duplicate the problem, I let it sit with the AC blowing and it just wouldn't. I don't trust it. I realize it may be fuel, or ignition, but I can't tell. Every thing checked out fine today. My question is can the ICM freak out when hot but still work, barely?
Btw I know opti is the 1st response, but I replaced it and the fuel pump 5000 miles ago, last year, the water pump is not leaking. Anyway thanks for reading this far.
Old Jun 17, 2007 | 11:43 AM
Yes, the ICM can heat soak. Shoebox has the fix:
http://shbox.com/1/4th_gen_tech2.html#ICM_cooling
The optical sensor in the Opti could also overheat.
Nayr
Mar 3, 2023 08:34 PM
Jeff1904
Jun 5, 2016 05:00 PM
93 RedBird
Nov 15, 2015 08:24 AM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
tdigger9899
Sep 7, 2015 10:56 AM
