4th gear sucks
Old Jun 17, 2007 | 01:37 AM
finalstage1's Avatar
4th gear sucks
my car is 95 formula and seems to be strong running car for being all stock in the motor area . <well its got an ls1 air intake> the problem is when i hit 4th gear the car does not have any pull . it runs good in 1st ,2nd, and 3rd but when i hit 4th its all over . i've raced a couple sti's and a couple neon turbos <srt-4> and i hold them off no problem until i hit 4th gear then they just come rite passed me . is this normal ?
heres what the car has
bfg drag radials
3.42 gears <was a 6 speed>
2500 stall
umi adj torque arm
adj pan hard bar
adj lca
ls1 drive shaft
Old Jun 17, 2007 | 01:44 AM
Daniel6718's Avatar
4th gear in an auto with 3.42 im asuming it doesnt pull because the wind resiatance above 140mph (about when you shift into 4th) is a lot...it take alota power to pull good in 4th..
prolly the 2500 stall is stock diameter and absorbing a lot of power also!
Old Jun 17, 2007 | 12:08 PM
4th gear is a 0.70 overdrive.... it turns your 3.42's into 2.38's. With 3.42's and a stock tire diameter, you can reach 127 MPH in 3rd gear at 5,700 RPM. If you're racing that fast on the street, you're insane.
Old Jun 17, 2007 | 12:10 PM
seawolf06's Avatar
Get a tune.
Magenta_Hearts
Mar 30, 2015 09:42 PM
Jul 4, 2005 05:00 PM
ksharr
Aug 30, 2002 10:58 AM
FireAm94
Aug 10, 2002 09:32 PM
