IAT resistor?
Old Aug 2, 2006 | 06:09 AM
  #16
01Z's Avatar
01Z
Re: IAT resistor?
Originally Posted by Injuneer
Did anyone who responded notice the person who asked the question has a speed-density 1993. That's the last setup you want to put a resistor in. The ECM needs the exact inlet air temperature to calculate the density of the air, so it can calculate the mass flow of the air, so it can calculate the fuel flow. Setting the IAT at a fixed temperature will really screw things up.
Its not the same as the 94+ MAF cars, where the IAT is used for little more than a possible 3* timing offset for very high inlet air temps.
No Fred. Thanks for explaining. That's why we're here....
Old Aug 2, 2006 | 10:03 AM
  #17
Dave '97 Z28 M6's Avatar
Re: IAT resistor?
No I did not notice that! I think my statement that it should not be done on any car makes sense. But you're absolutely right that there is no way you should modify the IAT on a speed-density car. Some people have relocated the IAT closer to the filter to avoid heat soak and give the PCM a more accurate reading of ambient temp, and I think that's OK.
Girrrrl
Aug 20, 2015 09:26 AM
Girrrrl
Aug 20, 2015 06:17 AM
PatriotTA
Feb 24, 2003 07:40 PM
badassT/A
3rd Gen / L98 Engine Tech
Jul 24, 2002 12:07 PM
badassT/A
Jun 22, 2002 02:37 PM
