Iacv
Old Jun 23, 2011 | 02:29 PM
mj1993z28's Avatar
idle air control valve
my question is could the idle air control valve cause the car to bog once its under load ? mis alittle possibly ? if it was dirty ? because my car idles fine .
Old Jun 23, 2011 | 02:37 PM
OBE1 95Z28's Avatar
Re: Iacv
Not likely; very little air passes through this valve and it's metered air so the engine management system is adjusting your fuel injectors to match.
Old Jun 23, 2011 | 02:50 PM
mj1993z28's Avatar
Re: Iacv
ok well i just took my throttle body off and cleaned the Idle air valve ... everything super clean now i start the car back up after putting everything back together now the car is idleing at 1500rpm ... really! high ! ,normally its like 600ish what did i do ?
Old Jun 24, 2011 | 05:28 AM
Re: Iacv
How did you clean it? You are not supposed to get any solvent in the motor, or you will damage it. You are not supposed to move the pintle by hand or you will damage it. Shoebox has a "reset" procedure - see if this works:
http://shbox.com/1/4th_gen_tech2.html#iac_reset
Also a check for the electrical side:
http://shbox.com/1/iac2.jpg
Dark Zeiro
Jul 19, 2015 08:25 AM
Dark Zeiro
Mar 11, 2015 07:15 AM
stockssn2o
Jan 1, 2014 02:35 PM
mj1993z28
Jul 10, 2011 09:58 PM
Garcia95
V6 Tech
Aug 14, 2009 05:02 AM
