The IAC passage in the intake goes where?
Old Jun 27, 2003 | 11:02 AM
quicksilver97ta's Avatar
On the front of the intake where the t.b. mounts there is a small hole that lines up with the IAC on the t.b. This is not open to the intake plenum but instead is a cast passage that goes where exactly?
Also, next to the passage, on the floor of the plenum there is a hole on each side. Where do they go?
Old Jun 27, 2003 | 11:06 AM
Buttercup's Avatar
There is a second plenum underneath the main one. Each intake port has a small hole that enters this. This was done to create consistent airflow to each cylinder at idle with such short runners.
Old Jun 27, 2003 | 11:17 AM
Thanks, BC. I never read that before. Any idea about the other two? EGR passages maybe? They where very dirty, like carbon.
Old Jun 27, 2003 | 11:54 AM
Buttercup's Avatar
Oops, didn't catch that part
I remember those other holes now, but I'll be damned if I can remember where they went. For some reason I want to say they go absolutely nowhere, would you confirm for me?
Old Jun 27, 2003 | 12:05 PM
Both the idle air and the EGR combine in the space under the base of the intake plenum, then flow through the little holes drilled in each manifold intake runner.
I'd have to look at my intake to remember where the other two holes you mention are even located.
Old Jun 27, 2003 | 12:10 PM
Buttercup's Avatar
They are immediately behind the TB openings, on the plenum floor. I'm almost positive they serve no function other than added volume to the plenum. Then again, I haven't looked at my intake for a year now
Old Jun 27, 2003 | 02:17 PM
Mikey97Z's Avatar
Cool
Hey! This discussion motivated me to post my "Intake Exploration" pictures.
http://web.camaross.com/forums/showt...hreadid=138756
It will explain all the holes you see in there!
Old Jun 27, 2003 | 02:21 PM
Excellent job! I've done the same thing, but I missed where the EGR ended up in the front of the intake. I though it combined with the IAC, and might explain why the IAC valve gets so dirty.
One minor point.... only the 95+ models (and certain earlier emissions variations) use the port under the TB for the PCV system. The 93/94 models have a pipe plug in that hole and connect the PCV directly to the drivers side of the intake plenum with a u-shaped hose.
Old Jun 27, 2003 | 02:53 PM
Mikey97Z's Avatar
Thanks, Fred! I'm wondering ... does that u-shaped hose attach to the hole in this pic that leads to the IAC passage?
http://z28.reanimator.org/stuff/intake/side.jpg
I'm thinking it should since the later models connect to the IAC passage, just through the front instead of the side. On my car this hole was used for vacuum to the EGR solenoid.
Old Jun 27, 2003 | 03:28 PM
Buttercup's Avatar
Good stuff Mikey
Old Jun 27, 2003 | 03:32 PM
Yes, that's where it connects....
Hard to see here
In 94, left is EGR vacuum, upper right is brake booster, and lower right is PCV
Old Jun 27, 2003 | 04:57 PM
That is a great write up, very good info there. Im fairly convinced somehow I am siphoning oil into the intake, especially the IAC passages after seeing this write up.
http://web.camaross.com/forums/showt...hreadid=138127
Its worse at idle and it's becoming very frustrating.
Old Jun 28, 2003 | 09:17 PM
arnie's Avatar
Hard to see here
Something didn't look quite right, then I realized being a '94, you added the vented opti. Hmmm, maybe that would make for a better/more effective vacuum source than the IAC vacuum for the opti vent line.
HectorM52
Jul 30, 2017 11:46 AM
rocknroler69
Parts Wanted
Jul 19, 2015 08:45 PM
lildemars09
May 28, 2015 07:54 PM
Zuvell
May 15, 2015 08:18 PM
lt1matt
Mar 21, 2015 07:35 PM
