Iac numbers ?
Old Jul 25, 2009 | 12:03 PM
ascastil's Avatar
Iac numbers ?
my car has been pullin a code po506 (i think that was it) when i use the ac. the iac numbers are 119 counts without it on and 130 with it on. the idle is at about 600 with the ac on also. it seems perfect with the ac off, just once you turn it on it messes up. are these numbers right? if not how do i fix them? ps the tps voltage is just right if you needed to know that.
Old Jul 25, 2009 | 08:24 PM
At idle, no A/C you should be seeing counts in the range of 20-40. Yours seems too high. What is a "just right" TPS voltage?
Sounds like the IAC motor may not be working correctly, or the IAC passage in the throttle body, or the pintle on the IAC motor may be carboned up. The scanner is telling you what counts the PCM it trying to move the IAC valve to. There is no feedback as to whether it is actually in the commanded position.
You don't mention whether the engine has any modifications, so we can't tell if there might be some reason like a huge cam that is affecting the idle speed/IAC counts.
Old Dec 2, 2009 | 12:09 PM
Wild1's Avatar
Is 20-40 IAC count for 350s or 383s... Or does size not matter.
Old Dec 2, 2009 | 02:50 PM
JAKEJR's Avatar
Same.
Jake
West Point ROCKS! Nation's TOP COLLEGE per Forbes Magazine!! Graduation Day Parade 20 May 2010!!!
Old Dec 2, 2009 | 02:55 PM
Wild1's Avatar
Thanks. I will check this weekend.
HectorM52
Jul 30, 2017 11:46 AM
rocknroler69
Parts Wanted
Jul 19, 2015 08:45 PM
F'n1996Z28SS
Jun 3, 2015 09:39 AM
lt1matt
Mar 21, 2015 07:35 PM
