IAC loudest part of engine! HELP!!
Old Mar 29, 2006 | 04:10 PM
30th TA 0219's Avatar
OK, think I finally got my miss/stutter issue solved, but before I put it all back together and drive it...
I fired it up straight open TB (no elbow etc) and the IAC is the loudest part of the engine! You can hear it sucking air over the LTs/Mufflex 4"!!!
When I plug the hole in the bottom of the TB (to the IAC valve) it runs great, and has a nice smooth, low idle. Before I was having erratic idle issues also.
Replace the IAC? What happens if I just plug it off? Or unplug the IAC altogether?
THANKS!!
Old Mar 29, 2006 | 04:34 PM
Re: IAC loudest part of engine! HELP!!
update, just unplugged the IAC motor, and it seemed to have no effecton anything, still hissing and sucking, and drowning out everything!
If I replace the IAC motor, sill this be solved? Where do I get one beside the dealer, AZ doesn't list one?
Old Mar 29, 2006 | 04:38 PM
blkchevyz's Avatar
you didnt just put a new throttle body on it did you?
the bbk/edelbrock ones whistle pretty bad, at least the old ones do.
my car use to sound like it had a blower.
Old Mar 29, 2006 | 04:40 PM
it does have a BBK 58 on it, but I mean this thing sound like a jet engine, and if I put my finger in it, it idles 100000% smoother!
Old Mar 29, 2006 | 04:43 PM
Cmr0z28's Avatar
My stocker hisses pretty loud.....so did Javier's when we started with no elbow.
Old Mar 29, 2006 | 04:49 PM
blkchevyz's Avatar
whats it doing besides making noise?
its might not even be the iac, i smoothed out the hole for the iac and it made mine alot quieter.
Old Mar 29, 2006 | 08:01 PM
well, like I said, it had an erratic idle before, but when I plug the hole COMPLETELY, it idles smoothly and at like 900rpm
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
jdohman
Jul 22, 2002 06:01 PM
