crank hub balancer clearance issue
Old Mar 28, 2006 | 06:31 PM
Ws6Envy's Avatar
The woodruf key on my crank was not long enough to drive the crank position sensor reluctor wheel, so i went with out it and had the cps deleted from the pcm.
but since the balancer went further down the crank snout i have a clearance issue at the balacer hitting the opti.....can i shim the balancer with a washer without screwing up anything? i measured the CPS reluctor wheel and i have a washer the exact thickness. Will it work?
Old Mar 28, 2006 | 09:13 PM
OBE1 95Z28's Avatar
Re: crank hub balancer clearance issue
The shim will work or a hub from a 93 - 95 F-Body.
Old Mar 29, 2006 | 08:28 PM
Ws6Envy's Avatar
thx man
camaro98_speed
Wheels and Tires
Mar 17, 2015 07:36 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
cyteone
Feb 7, 2015 06:04 PM
WantanLS1
Aug 5, 2002 02:45 PM
