IAC Count with just key on???
Old Feb 29, 2008 | 03:18 PM
chris96z's Avatar
I have had the stuttering and stalling problem for a while, but i have always just cleaned the IAC and problem solved. But I just tried to start the car and It stalled, stuttered, backfired and stopped running.... I have a scanmaster and with just the key on and not running my IAC readings are at 104. Does anyone know what they should be normally with just the key on? I already know what they should be at Idle.. Thanks
Old Feb 29, 2008 | 04:44 PM
The counts will be way high until it is started.
Old Feb 29, 2008 | 05:58 PM
chris96z's Avatar
Thanks for the reply Shoebox, but do you think my readings (104)and symptoms would be an indicator of the IAC going bad or do I have bigger issues?
Old Feb 29, 2008 | 10:29 PM
I don't think the 104 is abnormal.
Old Feb 29, 2008 | 11:23 PM
Sounds like many of the data logs that people send me. The IAC count with the KOEO is always way higher than the learned target IAC position.
Old Mar 1, 2008 | 12:12 PM
chris96z's Avatar
Well Here is the scoop, I went out and look for obvious signs of why It would not start, and I didnt see any thing out of the ordinary. So, I disconnected the battery for less then two minutes, reconnected it and the damn thing fired right up. What gives? Oh well I guess I will just drive it till the wheels fall off!
68camaroboltz
Oct 5, 2015 11:56 PM
colts0455
Oct 4, 2015 09:47 PM
colts0455
Sep 27, 2015 01:07 PM
KYWes
Sep 26, 2015 08:49 AM
autoxr166
Sep 25, 2015 04:21 PM
