IAC clearance issues
Old Feb 4, 2006 | 09:09 PM
LALT1's Avatar
Has anyone had any problems with their IAC hitting the water neck after installing a Plate Kit system??
Old Feb 4, 2006 | 09:14 PM
194bird's Avatar
Re: IAC clearance issues
yap sure did what i did was a grinder on the thermastate housing then a little on the iac housing must be running a 58 with that to arnt you
Old Feb 4, 2006 | 09:23 PM
LALT1's Avatar
yes sir, but you did get it to clear then and retain the IAC?
Old Feb 4, 2006 | 09:43 PM
194bird's Avatar
yes sir just do more grinding on the thermestate housing thant the iac housing becouse my first one i just grinded the iac housing and actauly went all teh way through before it fit but it will go just grind a little then check but start with the thermastate housing if you need i will try to get some pics of mine but it will be closer to the end of the week
Old Feb 4, 2006 | 09:53 PM
LALT1's Avatar
That would be great if you could man. I would greatly appreciate it.
camaro98_speed
Wheels and Tires
Mar 17, 2015 07:36 AM
'01BlackZ
Sep 3, 2002 09:53 PM
JasonD
Aug 27, 2002 10:57 AM
cryptopsy
Aug 14, 2002 05:44 PM
WantanLS1
Aug 5, 2002 02:45 PM
