IAC clearance issues
Has anyone had any problems with their IAC hitting the water neck after installing a Plate Kit system??:confused:
Re: IAC clearance issues
yap sure did what i did was a grinder on the thermastate housing then a little on the iac housing must be running a 58 with that to arnt you
yes sir, but you did get it to clear then and retain the IAC?
yes sir just do more grinding on the thermestate housing thant the iac housing becouse my first one i just grinded the iac housing and actauly went all teh way through before it fit but it will go just grind a little then check but start with the thermastate housing if you need i will try to get some pics of mine but it will be closer to the end of the week
That would be great if you could man. I would greatly appreciate it.
